Let's start with nanoCAD Tutorials...
In this video, you will acquire the knowledge about new tools for creating isometric drawings. These drawings show three sides at the same time - left, top, right and look 3D but are in fact 2D.
nanoCAD 22 introduces interactive parametric arrays. Instead of specifying their look with a dialog box or at the command line, you now interact with them while drawing the array. In this video, you will acquire the knowledge about how to work with interactive array in nanoCAD.
In this video, you will acquire the knowledge about how to place raster images, like photographs, in drawings, and then use them as backgrounds or to trace over them or change them.
In this video, you will acquire the knowledge about how to insert Drawings in Drawings (About DWG References) Sometimes you need to reference other drawings, and nanoCAD lets you insert those other drawings in the one you are working with. This is called 'DWG references' or 'external references' or 'xref' for short.
nanoCAD supports DWG file format, which makes it possible to open and edit drawing files from many other CAD programs. An unique feature about DWG is that it can define custom objects that are unique to one program. When you open such a drawing in nanoCAD, it allows displaying of custom objects as proxies - entities can be seen but cannot be edited very much. In this video, you will acquire the knowledge about how to work with proxy objects:
In this video, you acquire the knowledge about how to create and work with groups in nanoCAD. nanoCAD has several ways of working with groups of entities, and one of them is called "groups." Groups essentially are named selection sets. In this video, you learn how to create and insert blocks in drawings:
In this video, you acquire the knowledge about how to add attributes to and extract data from blocks:
In this video, you acquire the knowledge about how to edit and share blocks with other drawings:
In this video, you acquire the knowledge about how to create and insert blocks in drawings. A block is a symbol that you utilize a lot, for example a door or a bolt.
The new nanoCAD 23 release is full of new ways to create, compare and communicate.
Five optional modules 3D Solid Modeling...
Phone: +033 6623 6649
Mobile: +91 9748468686
For sales: sales@nanocad.in
For support: support@csoft.com
Web: www.nanocad.in
© 2023, All Rights Reserved.
