nanoCAD 3DScan 2.0 based on 20.1 version of nanoCAD platform. Thus, nanoCAD 3DScan 2.0 gets all features of nanoCAD Plus, since 8.5
The command Classification of Ground (NPC_CLS_GROUND) has been revised.
COMMAND OPTIONS ON THE “PROPERTIES” BAR
Now the command options are displayed and configured not in the command line, but on the Properties bar.
New command options:
FILTRATION BASED ON SOURCE CLASSES
The command allows you to specify certain classes of points for the ground classification process. It can be useful if a cloud was earlier classified by these or those criteria. For example, to exclude from the recognition process the points of noise, man-made objects, etc.
The Source classes parameter defines the classes of those points, that will be used for ground classification. Points of other classes will not be reclassified. The list opened by button displays all classes of the current point cloud.
The Ground class parameter is the target class, which should be assigned to recognized points of the ground.
The target class should coincide with none of the source classes, otherwise the command will stop ahead of time with an error message in the command line.
AUTOMATIC CALCULATING OF SURFACE DETALIZATION DURING GROUND CLASSIFICATION
Now the Cell size parameter is calculated automatically, based on the size of a point cloud in the drawing. As a rule, it should not be changed. In previous version of a program, the value of this parameter was taken from the Point clouds section of the Options dialogue. The Cell size defines the length of sides of square cells that divided surface of point cloud. The smaller the value, the more accurately relief elements are reflected. Parameter value is set in the units of drawing.
SURFACE IRREGULARITIES
We preserved the parameter Terrain angle, degrees – maximum angle of slope in degrees relative to XY plane in WCS. It can be measured at some characteristic area. Points on surfaces that exceed this angle will not be classified as ground surface points.Parameter Iteration angle, degrees to plane – maximum angle of deviation of local irregularities from the main direction of the ground surface.
FILTRATION BY DISTANCE FROM GROUND SURFACE
The Maximum distance parameter determines the maximum distance above the ground surface, above which points will not participate in the
classification process and, therefore, will not be classified as ground points. The distance is specified in the units of drawing.
EXCLUSION OF FALSE SURFACES
A new parameter Maximum window size allows you to exclude low buildings and constructions with flat wide roofs from ground recognition
It is necessary to find the widest low object and measure a half of its shorter side, increasing the resulting value by 20 percent. For each cloud the parameter should be set manually in the units of drawing.
Note: correctly measured parameter Maximum window size is always larger than Cell size parameter.
CLASSIFICATION OF VEGETATION
The command is enhanced with the functional for classification of points (vegetation) by height above ground level. Set Yes for the Classify vegetation option, additional options will appear.
The command classifies points located in the given altitude range relative to the ground surface. Values are set in the units of drawing.
Only ground surface points
Ground surface points with low vegetation points
Ground surface points, points of low, average and high vegetation
This procedure can be used not only to classify vegetation, but also to classify any objects by height from the ground surface: low constructions, high-rise buildings, power lines, pipes, etc.
CREATING TRIANGULATION MESH OF A SURFACE
In addition to ground surface classification, the command allows you to automatically construct its triangulation model as a mesh object. For this the value of Save ground model option should be Yes.“VEGETATION BY HEIGHT” COMMAND
The functional of objects classifying by height above the surface is also put into a separate command Vegetation by Height.
The command has parameters identical to those described above. As the surface relative to which the classification will be made, it is necessary to specify the existing triangulation mesh, for example, the one built earlier by the command Classification of ground or Create TIN.
FILTRATION BASED ON SOURCE CLASSES IN THE “CREATE TIN” COMMAND
The command Create TIN (NPC_2D_TRIANGULATION) got new options that allow you to select particular point classes for creation of triangulation mesh based on them. The options are similar to ground classification command Classification of ground (NPC_CLS_GROUND).
IMPORTING CLOUDS WITH WGS84 COORDINATE SYSTEM
The possibility to import point clouds from LAS format with WGS84 coordinate system is added. Previously clouds with WGS84 coordinate system were imported with distortion.
CHANGING CLASS FOR VISIBLE POINTS ONLY
A new command Classification by class (NPC_CLS_CLASS) changes class for visible points only. Just cut a part of cloud containing required points with one of the Clip or Section commands and reclassify only visible points by specifying their source class.
COLORING CLOUDS BY “COMPARE POINT CLOUDS” COMMAND
Now the command Compare Point Clouds colors the cloud according to the normal direction (outside/inside) when comparing a cloud with triangulation ground surface. The cloud above TIN surface is colored in the spectrum from green to red, and below – from green to blue. It allows easily determine the position of points relative to the mesh (ground surface).
In addition, the coloring of clouds was fixed when resetting clip after comparing their trimmed parts.
Changes and Corrections
