Operating system: |
Processor: |
RAM: |
Screen resolution: |
Graphics: |
Disk space: | 4 GB or more |
Network: | TCP / IP must be running on the license server and all workstations where applications using network licensing will work. |
.NET Framework: | .NET Framework version 4.0 |
Operating system: |
Processor: |
RAM: |
Graphics: |
Disk space: |
Additional hardware |
Operating system: |
Processor: |
RAM: |
Graphics: |
Support for the following DBMSs (for network database hosting): |
Operating system: | MS Windows® 10, MS Windows® 8, MS Windows® 7 |
Processor: | From 2 GHz, 4 GHz is recommended |
RAM: | From 4 GB, 8 GB or higher is recommended |
Hard disk space: | 4 GB or more |
Graphics: | Required resolution: 1024x768 with true color and OpenGL or DirectX-compatible hardware 3D acceleration, Recommended resolution: 1280x1024 or higher |
Additional hardware: | Mouse or other pointing device |
Screen resolution: | Minimum: 1280x1024, recommended 1920x1080 or more |
Database support (for Standard Parts Library on network): | Microsoft SQL Server 2005-2014; Microsoft SQL Server 2005-2014 express edition |
Operating system: | MS Windows® 10, MS Windows® 8, MS Windows® 7, MS Windows® Vista (SP1 or later) |
Processor: | Intel Pentium® 4/AMD Athlon® or higher. |
RAM: | From 512 Mb, 2 Gb is recommended if you have big projects. |
Hard disk free space: | About 300 Mb is required for full program installation, About 1-3Gb is required for working (according to the difficulty of projects) |
Graphics: | Video adapter with OpenGL or DirectX-compatible hardware 3D acceleration, Required resolution: 1024x768, Recommended resolution: 1280x1024 or higher |
